Sida 2 av 2
Re: Helljus - Vad kan man kräva?
Postat: 22 mar 2013, 10:05
av JMentzer
Ny insats till MY13 låter bra. Hoppas att vi som köpte 2012 kan byta in till nya lysen, i alla fall rabatterat. Som det är nu är under all kritik. Om inte annat så borde det funnits en typ "Nordic Light Edition" att välja som tillval.
Hoppas det löser sig innan nästa vinter!
Postat: 24 mar 2013, 11:41
av opus
jag kan bara hålla med om det har en IX35:a med ruttet helljus
Postat: 12 apr 2013, 21:36
av naderiano
Hej! Tänkte skriva lite här om mitt helljus också. I had a real real bad main beam as well as the others, I almost drove onto a traffic sign with my main beams on! This is what I did, I drove to Hyundai in Malmö and they adjusted it and said the problem comes from the leverans service... anyway, I then also changed the main beams to Philips XtremeVision H7 .. the difference after doing these modifications were great! No where near my previous Volvo S40, but much much better, I do recommend if you are annoyed by your main beam. Sorry I donät have any before, after pictures, but it was definitely worth it!
Hope this would help somebody..
Postat: 13 apr 2013, 14:18
av tjosan
naderiano skrev:Hej! Tänkte skriva lite här om mitt helljus också. I had a real real bad main beam as well as the others, I almost drove onto a traffic sign with my main beams on! This is what I did, I drove to Hyundai in Malmö and they adjusted it and said the problem comes from the leverans service... anyway, I then also changed the main beams to Philips XtremeVision H7 .. the difference after doing these modifications were great! No where near my previous Volvo S40, but much much better, I do recommend if you are annoyed by your main beam. Sorry I donät have any before, after pictures, but it was definitely worth it!
Det gjorde jag innan jag bytte till Xenon och det blev inte mycket bättre. Xenonen fungerar dock mycket bättre. Varför engelska?
Postat: 13 apr 2013, 22:04
av Slamsugarn
Sämsta helljuset som jag haft på en bil! Säljaren satte dit xenonkonverteringssats, men vi fick betala.Han visste om problemet,synd bara att han inte talade om det vid köpet.
Köper man en ny bil som de sålde in med reklamen "Nordens nya kombi",förväntar man sig ju att den går att köra med i mörker!!
Postat: 15 apr 2013, 13:23
av JMentzer
Jag kryper nog till korset och utrustar bilen med extra xenon. Vad kostar den där EX3000-rampen (inkl montage) som sätts under nummerplåten. Det vore bra med lite riktpriser innan beställning så jag vet att det blir till rätt pris
Postat: 20 dec 2013, 12:58
av marli
Hur ser jag om min bil har ny reflektor / lampa?
Jag har MY13 enligt chassino, dock köpt som en -12 av Hyundai.
Postat: 01 feb 2014, 13:35
av morsare
Jag har en 1.7crdi från 2013 och jag kan garantera att helljuset är lika jävla dåligt på denna årsmodell!!
Vad kostar konvertering/montering av extra ljus hos era försäljare?
min ville ha 5700 för en sån ramp som sitter under nummerplåten, och jag höll på gå i taket..
Postat: 10 nov 2014, 13:41
av Dalton
Kan någon bekräfta att det är nya lampor på 2013-2014 års modell. HIR2 skall jag visst ha i min bil.
Re: Sv: Helljus - Vad kan man kräva?
Postat: 12 nov 2014, 20:37
av Dalton
Sätter på vision x led ramp. Hoppas att problemet försvinner då.
Oneplus One
Postat: 12 nov 2014, 22:10
av tjosan
Dalton skrev:Kan någon bekräfta att det är nya lampor på 2013-2014 års modell. HIR2 skall jag visst ha i min bil.
Hjälper inte mycket om reflektorn är densamma. Utan gör som du skriver ovan, men det är löjligt på en bil från 2014-15.
Postat: 13 nov 2014, 06:48
av Dalton
Ljuset var ju löjligt dåligt, man undrar ju hur det var innan. Ramp är beställd.
Oneplus One
