RSVSR What Makes ARC Raiders Flashpoint Worth It
Postat: 01 apr 2026, 10:02
av Rodrigo
After a few matches with Flashpoint, it's pretty clear this patch has changed more than a couple of weapon stats. The flow of fights feels different now, and that's a big deal in a game where one loadout choice can decide whether you extract or get wiped. If you've been waiting for a reason to dive back in, messing around with ARC Raiders Items while learning the new tools actually makes the return feel worth it. This update doesn't play like filler content. It nudges people out of old habits, and honestly, that's what the game needed.
Canto changes the pace
The Canto SMG is the kind of gun that makes you want to move more. Not in a reckless way, but in that confident, push-forward style where you trust your weapon to stay on target. That's the first thing you notice. The recoil is light, the handling feels clean, and it doesn't punish you for firing while sliding around corners or cutting across cover. A lot of SMGs in extraction shooters either spray too wide or hit so softly that you lose every even fight. The Canto avoids both problems. It works best in close and mid-range scraps, especially when you're flanking or chasing a damaged enemy. Put it on a mobile build and you'll feel the difference right away.
Dolabra hits hard when it matters
The Dolabra Shotgun goes in the opposite direction, and that's why it stands out. This thing is made for players who like to force the issue and end fights fast. Up close, it's nasty. The energy-based design already gives it a different feel, but the real hook is the two firing modes. The wider shot is great for clearing smaller targets in cramped spaces, while the tighter mode gives you a focused blast for tougher ARC enemies that won't drop easily. That flexibility matters more than it sounds. You don't have to carry a backup weapon just to cover one weakness. The unlock grind is there, sure, but it doesn't feel wasted once you've got it in your hands.
Surge Coil rewards smarter squads
Not every fight in Flashpoint is about who lands the first burst. The Surge Coil proves that. It's a simple idea on paper, but in actual matches it can completely slow down an enemy push or buy your team a few crucial seconds. Toss it near a doorway, beside an objective, or in a lane where enemies love to funnel through, and suddenly they've got a problem to solve before they can even think about shooting. I've seen squads use it to protect revives, block rotations, and stall aggressive players who assumed they had an easy entry. That kind of utility gives support-minded players more to do, and it also makes coordinated teams feel stronger without making gunskill irrelevant.
Why the update feels worth your time
What makes Flashpoint click is that each new addition fills a real role instead of existing for novelty. The Canto rewards movement. The Dolabra gives you raw stopping power. The Surge Coil lets you control space and punish sloppy pushes. Put all that together and matches feel less predictable, which is a good thing for a game that can get stale when everyone runs the same setup. You start seeing odd team comps, riskier flanks, smarter holds. If you're jumping back in, it's a good moment to test fresh builds, farm for ARC Raiders Coins, and get comfortable with a version of the game that feels more alive than it did a week ago.
