PoE 1 Currency Class Tips Get Better Orb Deals at eznpc
Postat: 13 maj 2026, 11:53
Dying three times in a juiced map while your friend prints Chaos Orbs feels awful, especially when your build looked fine in Act 10. If you are trying to pick the best class for POE 1 currency farming, the answer is less about peak damage and more about how many clean maps you can finish before you get bored, distracted, or dead. Speed matters. So does staying alive.
Best Class for POE 1 Currency Farming: The Shortlist
Deadeye for fast mapping and early market pressure
Deadeye is still my first pick for players who enjoy bow builds and can tolerate a little danger. Lightning Arrow and Tornado Shot clear wide screens, hit Legion monsters before they fully wake up, and make Breach or Delirium feel smooth instead of cramped. In the first 72 hours of a league, that kind of speed can mean two or three extra maps per hour compared with heavier builds.
The catch is obvious once you hit nastier red maps. Physical spikes, bad positioning, and greedy altar choices can delete you. Personally, I would not start Deadeye unless I was willing to upgrade boots, bow, quiver, and ailment avoidance in small chunks instead of chasing one flashy multi-Divine item.
Necromancer for safer, steadier farming
Necromancer lacks the raw sprint speed of Deadeye, but it has a lovely advantage: your minions keep working while you loot, dodge, or panic-flask through ground effects. Skeleton Mages, Poison Summon Raging Spirits, and similar league-start setups are strong because they reach red maps without demanding expensive gear on day one.
This makes Necromancer excellent for Blight, Ritual, and Expedition. Stationary mechanics suit it. The weakness? Minion survivability and accuracy can become annoying later, especially against tougher bosses or map mods that punish minions. Still, from what I have seen, newer farmers make more consistent money on Necromancer than on glassy bow builds.
Pathfinder for flask uptime and awkward map mods
Pathfinder sits in the middle: fast enough to feel sharp, tougher than most bow Deadeyes, and comfortable in maps that would make other starters groan. Permanent flask uptime gives movement speed, resistance padding, recovery, and ailment control. Poisonous Concoction and Toxic Rain remain dependable choices because they scale well from levels and basic gear.
For Essence, Harvest, and lower-tier speed rotations, Pathfinder is underrated. It can chain short maps in under two minutes when geared sensibly. Not every player likes poison damage-over-time pacing, though. Honestly, some fights feel like waiting for a kettle to boil.
How to Turn the Best POE 1 Currency Farming Class Into Profit
Match the class to the Atlas strategy
A fast class used on the wrong mechanic is just noise. Deadeye should lean into Legion, Breach, and Delirium mirrors, where projectile coverage pays off immediately. Necromancer should look at Blight maps, Expedition logbooks, and dense Ritual encounters. Pathfinder shines with Essence rushing, Harvest lifeforce, and modifier-heavy maps where flasks solve problems before they become deaths.
Do not copy an expensive Atlas tree before your account is ready. You want Voidstones, enough Atlas passive points, and a map pool that does not collapse after ten runs. Otherwise, the best class for POE 1 currency farming will still feel poor because the engine underneath it is half-built.
A practical upgrade order
1) Buy or craft 30% movement speed boots as early as possible. If your character walks slowly, your profit is leaking every minute.
2) Upgrade damage in cheap, measurable jumps: flat elemental damage for bow builds, gem levels for minions, and damage-over-time multipliers for poison setups.
3) Fix defenses before luxury. Suppression, ailment avoidance, capped resistances, and life rolls prevent the worst farming killer: losing portals and momentum.
4) Spend less time in hideout. Price tabs once, roll maps in batches, and run ten maps before judging whether a strategy works. One unlucky map proves nothing.
Best Class for POE 1 Currency Farming Myths and Final Advice
Myth: boss killers are always richer
Bossing can be profitable, but mapping currency is usually friendlier to early-league players. Maven invitations, Uber bosses, and fragment sets require capital and mechanical comfort. A mapper earns through volume: raw currency, Scarab drops, league rewards, stacked decks, essences, and lucky Divine Orb moments. Boring? Sometimes. Effective? Very.
Myth: one class wins every league
Patch changes, Scarab reworks, league mechanics, and market prices can tilt the ranking. If a league rewards standing still in deadly circles, Necromancer rises. If open maps and projectile coverage dominate, Deadeye runs away with it. If annoying debuffs are everywhere, Pathfinder looks smarter by the day.
Pick the farmer that matches your hands, not just a tier list. Set up a ten-map test tonight, track deaths and profit, and if you need a safe shortcut for game currency or items while comparing builds, eznpc
is a practical reference point for what players value on the market. The class that keeps you mapping is the class that pays you back.
