Mmoexp:The Infinite Poison Build Breaking Path of Exile 2's Endgame
Postat: 24 jun 2026, 10:28
Summary: The Poison Acolyte of Chayula has emerged as one of the strongest endgame builds in POE 2 Divine Orbs. Using infinite poison stacking, powerful chaos damage scaling, and exceptional defenses, this budget-friendly setup can comfortably clear 200% Delirium maps and melt pinnacle bosses with millions of damage per second.
The Rise of Infinite Poison Stacking
As Path of Exile 2's endgame continues to evolve, players are constantly discovering powerful interactions that push builds far beyond their intended limits. One of the most impressive examples currently dominating the meta is the Poison Acolyte of Chayula, a build capable of stacking hundreds of poison effects on enemies while maintaining exceptional survivability.
What makes this build truly remarkable is its efficiency. Despite clearing some of the game's hardest content—including fully juiced 200% Delirium maps and pinnacle bosses—it can be assembled on a relatively modest budget of five to ten Divine Orbs. The core item enabling this strategy costs just a single Exalted Orb, making it one of the most accessible high-end builds available.
At the center of the build is the unique weapon Splinter of Lorata, a seemingly humble level-zero weapon with a game-changing modifier. It guarantees poison on every hit and removes the traditional poison stack limit, allowing any number of poison stacks to affect a target simultaneously.
Instead of being restricted to a handful of poison effects, enemies can now accumulate 100, 200, or even 300 stacks at once. When each poison stack deals thousands of damage per second, the result quickly escalates into millions of DPS.
Splinter of Lorata and Original Sin: The Perfect Combination
The build's offensive engine revolves around a clever interaction between Splinter of Lorata and Original Sin.
Normally, Splinter of Lorata prevents elemental damage from contributing to damage output, which creates an issue for scaling poison through elemental damage sources. However, Original Sin solves this problem entirely by converting all elemental damage into chaos damage.
Since poison scales from chaos damage, every source of elemental damage on rings, gloves, and other equipment effectively becomes a poison damage multiplier.
This interaction dramatically increases poison potency while preserving the weapon's ability to create unlimited poison stacks. The result is a build that scales both horizontally through stack count and vertically through increasing damage per stack.
With sufficient investment, individual poison stacks can exceed 5,000 damage per second. Multiply that by hundreds of simultaneous stacks, and bosses simply disintegrate.
Blasphemy, Repulsion, and Poison Propagation
The next major component is the interaction between Blasphemy and Repulsion.
Blasphemy converts curses into permanent auras, allowing Repulsion to automatically affect nearby enemies. Repulsion places a rune above enemies that triggers when they are struck, knocking them backward while dealing physical damage.
That physical damage is then converted into bleed and poison effects.
From there, Herald of Blood and Herald of Plague take over.
These heralds continuously spread poison and bleed throughout entire packs of monsters. As enemies die, chain reactions occur, causing additional poison explosions and further spreading damage across the screen.
The interaction creates one of the smoothest mapping experiences currently available in Path of Exile 2. Entire screens of enemies explode without requiring precise targeting, making high-density content significantly easier to farm.
Plague Bearer: The Real Screen-Clearing Monster
While poison stacking provides the raw damage foundation, Plague Bearer serves as the build's primary clearing tool.
As poison damage accumulates on enemies, Plague Bearer rapidly charges to maximum capacity. Once activated, it releases devastating waves of chaos damage capable of deleting entire packs instantly.
The most impressive aspect is how quickly it recharges.
Because poison is constantly spreading through Herald of Plague and Herald of Blood interactions, Plague Bearer frequently reaches 100% almost immediately after use. This allows players to repeatedly activate it while moving through maps.
The gameplay loop becomes incredibly simple:
Trigger poison stacks.
Activate Plague Bearer.
Watch enemies explode.
Recharge instantly.
Repeat.
Even bosses are vulnerable to this strategy. Multiple Plague Bearer activations layered on top of massive poison stacks create astonishing burst damage that can eliminate endgame encounters within seconds.
Arcanist of Chayula Adds Another Layer of Destruction
The Acolyte of Chayula ascendancy received a significant boost through the new Arcanist of Chayula node.
After dealing chaos damage and generating Glory, players can activate Arcanist of Chayula to gain substantial physical and chaos damage bonuses. More importantly, it summons Chayula tornadoes that deal damage independently.
These tornadoes can also poison enemies, adding even more stacks to already overwhelmed targets.
Against bosses, the tornadoes become a major source of supplementary damage while simultaneously helping recharge Plague Bearer. Combined with poison propagation mechanics, the entire build becomes a self-sustaining engine of destruction.
Unexpected Minion Synergies
One of the most creative aspects of the build is its use of minions.
The Dark Defiler Rattling Scepter grants skeletal warriors and converts the presence of undead minions into additional chaos damage. Rather than investing heavily into minion damage, the build uses minions purely as support tools.
A permanent Gas Arrow Archer equipped with Kreugal's Leash provides Unholy Might, granting 30% of damage as extra chaos damage.
This bonus significantly increases poison damage output.
Additional skeletal warriors and a Skeletal Sniper further boost scaling while remaining relatively inexpensive to maintain. The Wolf Pack spirit skill adds another layer of utility by absorbing damage and triggering powerful Abyssal modifiers through Amon Namu's Tithe.
Together, these seemingly minor interactions contribute enormous amounts of bonus chaos damage.
Defensive Power Matches Offensive Strength
Many glass-cannon builds struggle in difficult endgame content, but the Poison Acolyte of Chayula excels defensively as well.
The build combines:
High evasion rating
Massive deflection chance
Ghost Shrouds
Energy Shield recovery
Life recovery from poisoned enemy kills
With proper gear, players can achieve over 70% evasion and roughly 90% deflection.
Ghost Shrouds constantly restore Energy Shield whenever damage is taken, making incoming hits far less threatening. Meanwhile, poison-related recovery nodes provide continuous healing as enemies die.
The result is a surprisingly durable character capable of surviving even heavily modified Delirium encounters.
While occasional deaths can still occur in the most dangerous content, the build remains far tankier than most damage-focused alternatives.
Scaling Beyond the Budget Version
Although the build functions exceptionally well on a modest budget, there is plenty of room for further investment.
High-end upgrades include:
Premium evasion chest pieces
Advanced deflection gear
Perfect Energy Shield boots
Upgraded Splinter of Lorata with additional sockets
Palm of the Dreamer scepter
Enhanced poison jewels
Additional Runic Ward scaling
These upgrades can push the build's damage and survivability to absurd levels, though costs quickly climb into the hundreds of Divine Orbs.
Fortunately, none of these upgrades are necessary for success. Even the budget version comfortably handles pinnacle bosses and fully juiced Delirium content buy POE 2 Divine Orbs.
Final Thoughts
The Poison Acolyte of Chayula demonstrates just how powerful Path of Exile 2's build system can become when multiple mechanics interact perfectly. Infinite poison stacking, Plague Bearer explosions, chaos damage scaling, and exceptional defenses combine to create one of the most complete endgame builds currently available.
What makes the build particularly appealing is its accessibility. Unlike many top-tier builds that require enormous investment, this setup reaches incredible power levels with surprisingly affordable gear.
For players looking to farm Delirium maps, destroy pinnacle bosses, and experience one of the strongest poison archetypes ever seen in Path of Exile 2, the Poison Acolyte of Chayula may be the perfect choice. With hundreds of poison stacks melting enemies and entire screens exploding at the press of a button, it's easy to see why many players are calling it one of the game's most dominant endgame builds.
Recharge instantly.
Repeat.
The build combines:
High evasion rating
Ghost Shrouds
Final Thoughts
