EZBUFF | How to Earn POE 2 Currency While Completing Side Quests
Postat: 26 aug 2026, 09:03
av LunarEcho
Side quests in Path of Exile 2 are more than optional distractions. When approached efficiently, they can provide useful rewards, valuable equipment, crafting materials, and opportunities to build your overall POE 2 Currency supply. The key is to combine quest progression with efficient exploration rather than treating every side quest as a separate trip.
Choose Side Quests With Useful Rewards
Not every side quest offers the same economic value. Before investing significant time, consider what the quest actually provides. Rewards that improve your character immediately can reduce the amount of currency you need to spend on upgrades later.
Look for quests that provide equipment, skill-related rewards, crafting resources, or access to areas containing additional enemies and loot. Some rewards may not have a direct trade value, but their practical value can still be significant. Saving yourself from buying an upgrade is effectively another form of currency preservation.
Combine Questing With Loot Farming
The most efficient approach is to avoid making separate runs for every objective. When traveling toward a side-quest location, clear worthwhile enemy groups along the route and inspect valuable drops. Rare equipment, useful bases, and crafting materials can contribute to your long-term wealth.
Inventory management matters as well. Picking up every low-value item can quickly fill your inventory and force unnecessary trips back to town. Instead, prioritize items that have meaningful vendor, crafting, or trading potential. This keeps your side-quest runs productive without sacrificing too much time.
Use Side Quests to Improve Your Character
A stronger character can farm more efficiently, which indirectly increases your future POE 2 Currency income. If a side quest provides a permanent benefit or an upgrade that improves your build, completing it can be more valuable than immediately chasing a small amount of tradeable loot.
Pay particular attention to rewards that improve survivability, damage, or resource management. A well-developed character can clear areas faster and handle more challenging content, creating better opportunities to earn valuable items.
Manage POE 2 Orbs Carefully
Crafting materials and POE 2 Orbs should be treated as resources rather than items that must be spent immediately. While leveling, avoid using valuable currency on temporary equipment unless the upgrade provides a substantial improvement.
Instead, save higher-value resources for important gear upgrades or crafting opportunities. Lower-value materials can often be used more freely when they provide a clear benefit. This approach prevents side-quest rewards from disappearing through unnecessary crafting decisions.
Consider Buying Currency Only When It Makes Sense
Some players may eventually consider whether to buy POE 2 Currency when they want to accelerate a specific upgrade. If you choose this route, treat it as a convenience rather than a replacement for normal progression. Set a budget, use reputable services, and understand the game's rules before making any transaction.
For players who prefer to manage resources through gameplay, EZBUFF can also be used as a reference point when thinking about currency values, item priorities, and upgrade planning. The most important principle is to make spending decisions based on actual character needs rather than temporary excitement.
Plan Each Questing Session
Before starting a session, identify several side quests located in the same general area. Complete objectives in one route whenever possible, while collecting worthwhile loot along the way. This reduces travel time and increases the amount of productive gameplay you get from each run.
By combining side-quest rewards, efficient looting, careful crafting, and sensible spending, you can steadily build your resources without turning currency farming into a separate chore. The best strategy is to make every quest contribute something useful to your character and your long-term economy.
