All-New D4Gold.com Points System Guide: Daily Check-ins and More
Postat: 21 sep 2026, 10:35
Welcome to D4Gold.com! To thank you for your continued trust and support, we are officially launching the all-new D4Gold Points System, designed to bring you more rewards and flexible shopping benefits.
Whether you are a newly registered user, a long-time VIP member, or a returning customer, you can earn Points through daily check-ins and by completing eligible orders. These Points can then be used to directly offset the cost of future purchases.
This guide covers how to earn Points, the 10x reward for your first order, Points validity, Points calculations following refunds, and how to choose between Points, VIP Discounts, and Discount Codes.
Points System Requirements
D4Gold Points are available exclusively to registered and logged-in users. Upon registration, your account automatically starts at VIP Level 1, currently offering a 1% discount. As your cumulative spending increases, your VIP Level can rise:
• VIP Level 1: 1% OFF
• VIP Level 2: 2% OFF
• VIP Level 3: 3% OFF
• VIP Level 4: 4% OFF
• VIP Level 5: 5% OFF
VIP Discounts and Points can be used simultaneously. By consistently using the same D4Gold account, you can accumulate Points while enjoying higher order discounts as your VIP Level rises.
Points, VIP Levels, and other account benefits are tied to your specific account and cannot be transferred, merged, or gifted to other accounts.
How to Earn Points?
Currently, there are two main ways to earn Points: daily check-ins and completing eligible orders.
Daily Check-in Points
Earn Points by logging in and completing the daily check-in. The longer your consecutive check-in streak, the more Points you earn each day:
• Day 1: 8 Points
• Day 2: 10 Points
• Day 3 and beyond: 12 Points per day
If you miss a day, your consecutive check-in streak resets. Your next check-in will start over at Day 1 rate (8 Points) rather than continuing at the 12-point daily rate. Daily check-ins are calculated based on the refresh time of the time zone where your D4Gold account was registered.
Checking in close to the refresh time carries a risk of missing the day's check-in because of network latency or page loading issues; this would break your consecutive check-in streak, causing the count to reset to Day 1 (8 Points) upon your next check-in.
Therefore, to ensure you consistently maintain your consecutive check-in rewards, we recommend completing your daily check-in well before the refresh time.
Where to Check In?
D4Gold offers multiple access points for check in, so you don't have to search for the specific page every time:
1. Go to My Account → Check In and click the current date on the calendar or CLAIM POINTS TODAY button at the bottom of the page.
2. Click CLAIM POINTS TODAY on My Orders, Personal Settings, or My Coupon pages.
3. Click Claim Now & Save More banner on the homepage for quick access to the check-in page.
4. Visit VIP Member page and click CLAIM POINTS TODAY to check in and collect the day's Points.
5.Click Claim Now & Save More banner directly on any product page to complete your daily check-in while browsing products.
Order Points
In addition to daily check-ins, you can also earn Points by completing eligible orders on D4Gold.com.
The base earning rate for standard orders is: $1 spent = 1 Point
Points are calculated based on the order subtotal. Amounts with decimals are rounded to the nearest whole number.
For example:
• An order of $55.26 earns 55 Points.
• An order of $41.56 earns 42 Points.
However, Points are only awarded for orders with a subtotal of $5 or more.
Orders with a subtotal below $5 do not generate Points. If you plan to purchase multiple items, consider combining them into a single order to avoid missing out on Points due to a low order value.
When are Points Credited?
Points are not credited to your account immediately after payment for a standard order.
Points are only added to your account once the order has been successfully completed and its status changes to Completed.
Points are not awarded for orders that are voluntarily cancelled, fully refunded, flagged for suspected fraud, or otherwise not successfully completed.
Therefore, it is normal for Points not to appear in your account immediately after a successful payment.
Partial Refund
If a partial refund occurs on an order for which Points have already been issued, the system will readjust Points generated by that order based on the refund amount and simultaneously return a proportional amount of Points used during the initial purchase.
Points earned from the order will be deducted based on the actual refund amount, so rounded to the nearest whole number.
If Points were used when placing the order, the returned amount is calculated using the following formula:
Returned Points = Points Used × (Refund Amount / Original Purchase Amount)
For example, suppose an account has 446 Points and places a $55.26 order, using all 446 Points to offset $4.46 of the cost.
This order would originally earn 55 Points.
If $15.02 of the order is subsequently refunded, approximately 15 Points must be deducted from the earned total, leaving a final balance of: 55 - 15 = 40 Points
446 Points originally used will be returned based on the refund ratio: 446 × ($15.02 / $55.26) ≈ 121 Points
The account will ultimately receive: 121 Returned Points + 40 Earned Points = 161 Points
Full Refund and Order Issue
If an order is voluntarily cancelled, fully refunded, flagged for fraud risk, or not successfully completed, no reward Points will be issued for that order.
Once an order has been successfully delivered and confirmed as complete, refund requests based on user-initiated reasons are not accepted.
If an order cannot be delivered and a refund is issued because of D4Gold.com's inventory, technical issues, or other internal factors, any Points used for that order will be returned based on the actual refund amount.
10x Points for New Users
Besides standard order rewards, newly registered users can earn 10x New Customer Points on their first eligible order.
Standard orders are calculated at: $1 = 1 Point
Whereas eligible first orders for new users are calculated at: $1 = 10 Points
For example, if a new user's first order has a subtotal of $50, they would normally receive: 50 × 10 = 500 Points
Based on the redemption rate of 100 Points = $1, this equates to $5 worth of Points that can be used for future orders.
First Order Under $5
A new user's first order is defined as the first successfully paid order placed on the account, regardless of whether that specific order earns Points.
For example, suppose a new account's first order is only $4.99.
Since the subtotal does not reach the $5 threshold, this order will not earn any Points, yet it will still be recorded as the account's First Order.
Consequently, even if a subsequent order reaches $50, the account will no longer qualify for the 10× New Customer Points promotion; Points will instead be awarded according to standard order rules.
Therefore, if you plan to purchase multiple items after registering, it is recommended to combine them into a single first order and ensure the subtotal is $5 or higher.
When 10× Points are Credited?
New Customer Points are subject to additional anti-fraud and risk assessment reviews.
Once the first order has been successfully delivered and confirmed free of refunds or irregularities, the 10× Points will be credited to the account within 24 hours.
Creating multiple accounts or repeatedly claiming New Customer Benefits via linked IP addresses, devices, payment accounts, or other methods may trigger the risk control system.
Points Value
D4Gold Points can be used directly at checkout to offset a portion of the order total.
The current redemption rate is fixed at: 100 Points = $1
Meaning: 1 Point = $0.01
For instance, having 500 Points in your account is equivalent to having $5 in credit to apply toward purchases.
Points are considered account rewards; they cannot be exchanged for cash, withdrawn, or transferred to other accounts.
Points Expiration
Points are valid for 90 days, with the validity period calculated individually for each batch of Points based on the date they are credited to the account.
For example, if a batch of Points is credited on Day 1, it will expire on Day 91. Points earned at different times have separate expiration dates; therefore, when accumulating Points over the long term, we recommend checking your balance regularly and using them wisely to prevent expiration after 90 days.
Maximum Points Deduction
The maximum deduction amount using Points is calculated in tiers based on the order subtotal:
Order Subtotal Max Points Deduction
$5.00 - $39.99 7%
$40.00 - $99.99 9%
$100.00+ 11%
The higher the order amount, the higher the maximum percentage that can be deducted using Points.
For example, on a $60 order, the maximum deduction using Points is approximately 9% (i.e., $5.40), corresponding to a maximum usage of about 540 Points.
The actual number of Points you can use also depends on your account balance.
Points + VIP Discount: Supported
Can Points be used in conjunction with VIP Discount?
Yes.
Points can be used alongside your account's VIP Discount.
For instance, a newly registered user with a VIP Level 1 status (1% off) can use Points to further reduce the actual payment amount on top of VIP Discount.
The higher VIP Level, the greater the total savings offered by this combination.
Points + Discount Code: Not Supported
Can Points be used with a discount code?
No.
Points and Discount Codes are two different promotional options and cannot be used simultaneously on the same order.
At checkout, the system compares:
• VIP Discount + Points
• Discount Code
The option that provides the better final price will be applied as Best Deal. You can also manually switch between available options at checkout.
Points vs. Discount Code
Which option offers better value depends on the discount currently available, your VIP Level, your order subtotal, and the number of Points in your account.
Points can be combined with your VIP Discount, while Discount Codes may offer different discount rates depending on the current promotion.
For example, larger orders allow a higher maximum Points deduction:
• $5.00 - $39.99: up to 7%
• $40.00 - $99.99: up to 9%
• $100.00+: up to 11%.
If you have enough Points available, combining Points with your VIP Discount may provide greater savings. However, if the current Discount Code offers a stronger discount or your Points balance is limited, Discount Code may be the better option.
Because Discount Code rates may vary, there is no fixed threshold at which one option is always better than the other.
Points are also valid for only 90 days. If the savings between the two options are similar, you may want to use Points that are close to expiring.
The final payable amount should always be based on Best Deal shown at checkout.
Frequently Asked Questions(FAQ)
Q1: Can I register multiple accounts to repeatedly claim the 10x Points offer for first-time orders?
A: We do not recommend doing this.
10x New Customer Points offer is subject to risk assessment. If the system detects multiple accounts sharing the same IP address, device, payment account, or other anomalous links, those accounts may be disqualified from receiving the promotional Points, and any rewards already issued may be revoked.
Accounts found to be seriously abusing the promotion may also face restrictions.
Q2: Can VIP levels and Points be transferred to another account?
A: No.
VIP levels, Points, and associated account benefits remain tied to the account where they were originally earned; they cannot be transferred, merged, or gifted to other accounts.
Therefore, if you plan to use D4Gold.com in the long term, we recommend sticking to a single account.
Q3: Can I restore my consecutive check-in streak if I miss a day because of network issues?
A:If a check-in is missed because of personal network latency or failure to check in before the daily reset, the record will reset according to standard rules; customer service cannot manually restore a missed day's check-in.
If the issue is confirmed to be caused by a widespread server outage or technical problem on D4Gold.com, a general announcement regarding Points compensation will be issued based on the situation.
Key Tips for New Users
For newly registered users, the most important Points rules can be summarized as follows:
• Upon registration, your account starts at VIP Level 1 with a 1% discount, and you can begin earning Points through daily check-ins and eligible orders.
• Make sure your first order reaches $5. First Order status is determined by the first successfully paid order. If your first order is only $4.99, it will still count as your First Order, but you will not receive the 10x Points bonus.
• Check in every day. After reaching a 3-day consecutive streak, you can earn 12 Points per day. If the streak is broken, your next check-in will restart at 8 Points.
• Use Points before they expire. Points are valid for 90 days from the date they are credited to your account.
• Compare VIP + Points with the current Discount Code at checkout. Discount Code rates may vary, so the better option depends on your VIP Level, Points balance, order subtotal, and the promotion currently available. The checkout page will automatically display Best Deal.
• Points are adjusted accordingly in the event of a partial refund. Points originally earned from an order will be deducted based on the refund amount, while Points already redeemed will be returned proportionally based on the refunded amount.
If you have any further questions about Points, orders, VIP benefits, or Discount Codes, please feel free to contact D4Gold.com online customer support.
D4Gold.com reserves the right of final interpretation regarding Points System and related promotional rules.
How to Earn Points?
• Day 1: 8 Points
• Day 2: 10 Points
Where to Check In?
Order Points
For example:
Partial Refund
Points Value
Points Expiration
$5.00 - $39.99 7%
$40.00 - $99.99 9%
$100.00+ 11%
Yes.
No.
• Discount Code
A: No.
