MMOexp:Most FC 26 Players Are Wasting Hours on Journey of Nations
The Festival of Football promotion in FC 26 has introduced one of the most rewarding objective sets of the year: the Journey of Nations North America challenge. At first glance, the objective list looks overwhelming, featuring dozens of tasks spread across the United States, Canada, Mexico, Haiti, Panama, Brazil, and special player journeys. But what if almost all of these objectives could be completed simultaneously with a carefully planned squad setup? By following the right progression path, players can unlock the outstanding 95-rated Sanchez card, earn 100 Festival of Football Tokens, and collect a huge collection of packs, player picks, EA FC 26 Coins, and special cards in less than an hour.
Why Journey of Nations Is Worth Completing
Many FC 26 objective programs offer decent rewards, but Journey of Nations stands out because of the sheer volume of content available.
Completing the full challenge rewards players with:
95-rated Sanchez
Multiple Evolutions
High-rated player picks
Special Festival of Football cards
National kits, badges, and tifos
Valuable fodder packs
10,000–20,000 coins
Several usable Ultimate Team players
The centerpiece is Sanchez himself. His combination of Finesse Shot+, Low Driven+, Technical+, and First Touch+ makes him a dangerous attacker in the current FC 26 meta. Add Pinged Pass, Quick Step, and strong overall stats, and he becomes a card that can genuinely improve many Ultimate Team squads.
The Biggest Mistake Players Are Making
The largest reason players struggle with this objective set is simple: they try to complete every challenge individually.
That approach dramatically increases the number of matches required.
Instead, the key is understanding that many objectives overlap. A single match can contribute progress toward USA, Mexico, Canada, North America, Brazil 94 Triumph, Captain's Header, and Dempsey's Journey all at once.
When approached efficiently, the entire grind becomes surprisingly short.
Step One: Complete Street Soccer First
Before building your main squad, head directly into Rush mode and focus on the Street Soccer objectives.
You need to:
Win one Rush match
Score seven goals
Assist five goals
Win by at least two goals
Use any North American player while working through these tasks.
The real reason to start here, however, is Clint Dempsey.
One assist in any Ultimate Team mode unlocks his special card for free. There is absolutely no reason to buy him from the market.
Once unlocked, you need to:
Assist with Clint Dempsey
Score a low-driven goal with Clint Dempsey
If possible, complete these tasks while finishing Street Soccer. If another player selects Dempsey in Rush before you can, don't worry. Finish Street Soccer first and complete Dempsey's objectives afterward.
The goal is to finish both Street Soccer and Dempsey's Journey before moving on to the main grind.
Step Two: Build the Perfect Starting Squad
The entire strategy revolves around maximizing overlap between objectives.
Your first squad should contain:
6 American players
3 Mexican players
1 Brazilian player
1 flexible player
Use the 4-4-2 (2) formation because it is required for the Brazil 94 Triumph objectives.
The Brazilian player can simply be your goalkeeper. This is the easiest way to satisfy the Brazilian requirement without affecting squad chemistry or performance.
Clint Dempsey should be one of your American attackers because you'll need him for multiple low-driven goals.
Why Six Americans Are Essential
The USA objectives are among the longest in the entire challenge.
You need to:
Play matches with American players
Win matches with Americans
Assist through balls in separate matches
Score low-driven goals
Complete Go USA objectives requiring six Americans
Because these objectives take the most matches, it makes sense to start with six Americans immediately and leave them in the squad until every USA objective is complete.
This allows virtually every game you play to count toward American progress.
Completing Mexico at the Same Time
While six Americans are locked into the squad, your remaining slots should be occupied by three Mexican players.
This setup simultaneously progresses:
Mexico Objectives
Win one match with a Mexican player
Play three matches with three Mexicans
Concede no more than three goals
Score seven goals
The beautiful part is that you do not need Mexican players to score those goals.
Any player can contribute.
That means Dempsey and your other attackers can continue advancing USA objectives while Mexico progresses naturally in the background.
Most players will complete Mexico before finishing USA.
Once Mexico is complete, remove the Mexican players from your squad.
Don't Rush Raphael Marquez
Many players panic when they see the Captain's Header objectives.
The common assumption is that they must score a header with Raphael Marquez.
Fortunately, that is not true.
To complete the objective group, you only need three segments.
That means:
Unlock Marquez
Play matches with Marquez
Win matches with Marquez
The header objective can often be skipped entirely.
This saves considerable frustration, especially for players who struggle to score headers consistently.
Simply unlock Marquez through the clean-sheet requirement and use him later when needed.
The Best Modes to Use
Many players instinctively choose Squad Battles.
That is usually a mistake.
The fastest options are found in Live Events.
Recommended modes include:
Prime Heroes Events
These feature:
Short matches
Maximum chemistry
Fast completion times
Visa Tap-In Event
Benefits include:
Unlimited attempts
Quick matches
No special squad restrictions
Season 8 Exhibition
This mode is particularly valuable because:
Matches are first to three goals
Games finish quickly
Progress stacks efficiently
Golden Goal Events
Whenever Golden Goal events become available, use them immediately.
One goal can end an entire match, dramatically reducing completion time.
These modes make the difference between spending several hours on objectives and finishing everything in under an hour.
Transitioning Into Canada
After Mexico is complete, replace the three Mexican players with four Canadian players.
Now your squad should contain:
6 Americans
4 Canadians
Brazilian goalkeeper
This setup allows you to continue progressing USA while beginning Canada.
The Canadian objectives require:
Two assists in one match
Two finesse goals
Lobbed through-ball assists
Wins with Canadians
Matches played with Canadians
At this stage, focus on two things simultaneously:
Through-ball assists for USA
Lobbed through-ball assists for Canada
Since both objectives require separate matches, you can often progress them together.
Continue scoring low-driven goals with Dempsey while doing this.
Finishing the USA Grind
Eventually you'll complete:
Five matches with Americans
Three wins
Three through-ball assists
Six low-driven goals
At that point:
USA = Complete
Go USA = Complete
This is the major turning point in the grind because Americans are no longer required.
You can finally remove them from your lineup.
The Final Squad Setup
Once USA is finished, transform the squad into:
6 Canadians
Raphael Marquez
Brazilian goalkeeper (if still needed)
Remaining flexible spots
Now focus entirely on:
Canada's remaining wins
Canada's remaining matches
North America objectives
Since Canada requires six Canadians for the North America challenge, these objectives naturally complete together.
Most players only need about three additional victories at this stage.
After those wins, virtually every remaining objective will be complete.
How Few Matches Does This Actually Take?
The efficiency of this method is remarkable.
In an ideal scenario:
Rush
1 match
Live Events
9 matches
Total:
Around 10 matches
Even if things don't go perfectly and you need additional games for assists, wins, or low-driven goals, most players should finish in:
60–80 minutes
Compared to traditional objective grinding, that is incredibly efficient.
The Massive Reward Pool
The rewards extend far beyond Sanchez.
Throughout the journey you'll unlock:
USA Rewards
Clint Dempsey
Austin Trusty
Christian Pulisic
DeMarcus Beasley
Various player picks
Evolutions
Canada Rewards
Jonathan David
Alphonso Davies
Promise David
Buchanan
Additional Evolutions
Mexico Rewards
Rafael Marquez
Campos
Pina
Reyes
Mexican-themed cosmetics
Haiti and Panama Rewards
Pierre
Cordoba
Etienne Jr.
Kits and badges
Additional Rewards
85+ packs
86+ player picks
87+ player picks
Evolutions
Coins
Cosmetic items
Many of these cards can immediately help complete later objectives, making the process even smoother as you progress.
Is 95 Sanchez Worth the Grind?
Absolutely.
Even ignoring the 100 Festival of Football Tokens, Sanchez alone offers tremendous value.
His combination of:
Finesse Shot+
Low Driven+
Technical+
First Touch+
fits perfectly into FC 26's attacking meta.
With four-star skills and five-star weak foot, he provides versatility in front of goal, while Quick Step and Pinged Pass ensure he remains effective in both build-up play and finishing situations cheap EA FC 26 Coins.
Considering the relatively short completion time, Sanchez is arguably one of the best objective cards released during the Festival of Football.
Final Verdict
The Journey of Nations North America challenge initially looks intimidating because of the huge number of objectives. However, the secret is understanding how heavily the tasks overlap. By starting with Street Soccer, unlocking Clint Dempsey immediately, using a squad built around six Americans, three Mexicans, and one Brazilian, then transitioning into a Canadian-heavy lineup, players can complete nearly every objective simultaneously.
Instead of grinding dozens of matches across multiple modes, most players can realistically finish everything in around an hour while earning a mountain of rewards. The result is a fantastic 95-rated Sanchez, 100 Festival of Football Tokens, multiple Evolutions, valuable packs, special cards, and enough additional content to significantly strengthen an Ultimate Team squad.
For pure rewards-per-minute value, this may be one of the best objective programs FC 26 has released all year.
