There's a reason budget raid videos keep pulling people in: they show what actually works when you're not walking in with a fortune on your back. In Terasito's latest Viewer Budget Gun session, the P90 gets its turn under a tight 250k cap, and it doesn't feel like a throwaway setup at all. The whole run is a neat reminder that smart choices around Delta Force Items can matter more than simply buying the loudest, priciest kit in the stash.
Why the P90 feels so good on a budget
The P90 is one of those guns that rewards confidence. You don't hold long angles with it and pretend you're a sniper. You move. You listen. You get close enough that its fire rate becomes a problem for anyone in front of you. This build leans into that idea with a suppressor, a longer barrel, a clean holographic sight, and tuning focused on keeping the weapon steady during ugly, rushed fights. It's not fancy, but it's practical. That matters in raids where a single bad reload or wide swing can send you back to the lobby.
Messy fights make the build look better
What stands out in the run isn't just the weapon. It's how the player handles the chaos. There are moments of slow crouch-walking, odd repositioning, and straight-up hiding when the situation gets too noisy. Then, a few seconds later, there's a hard push into a room because the timing feels right. That's very raid-like. Plans fall apart fast. Another squad appears, footsteps come from the wrong hallway, and suddenly the cheap gun has to earn its place. Some players use outside markets to speed up testing different setups, including resources like Delta Force Tekniq Alloy for sale, but the run still makes one thing clear: gear helps, yet decision-making keeps you alive.
Easy mode changes the rhythm
The discussion around easy mode versus normal mode is worth paying attention to. Easy mode gives you more room to breathe. Fights last a bit longer, mistakes don't always mean instant death, and budget guns have time to show what they can do. That makes it a solid place to learn routes, test recoil, and figure out how players rotate through contested areas. Normal mode is harsher. Better armour, faster deaths, and less forgiveness make every peek feel expensive. You can still run cheaper builds there, sure, but you've got to be cleaner. No lazy swings. No standing in open doors. No pretending sound doesn't matter.
Cheap gear still needs a good pilot
By the time extraction is on the table, the P90 has already done more than enough to prove the point. The loot haul is strong, the fights are memorable, and the whole setup feels like something regular players could copy without draining their stash. That's the real appeal of this kind of run. It doesn't sell the idea that budget gear magically beats everything. It shows that a simple, well-tuned weapon in the hands of someone paying attention can punch way above its price. For players trying to stretch resources, learn maps, or just enjoy raids without sweating every lost coin, that's a pretty useful lesson.
