Auto-window relay kit has the following functions.
One-touch up and down functions for driver's and passenger windows
Remote control auto up and down functions - Arm the alarm, and all windows go up. Disarm-arm-disarm the alarm within a space of 4 seconds, and the windows will roll down automatically.
Emergency stop function - If something gets caught in the window while it is closing, the motor will stop.
Pressure relief function - Windows will go down 2 cm when the door is opened, and go back up after the door is closed, relieving the pressure within the car when the door is slammed shut. This is the same function that is standard on BMW and MB cars with frameless doors.
All functions can be disabled by pressing the window-lock button on the driver's side.
The relay kit consists of connectors which are connected to the OEM connectors on the car, but also require splicing four wires.
The relay kit for the 03-08 is only applicable for cars with only auto-down function. If there are any Tiburons with auto-up and auto-down, this kit will not work.
Den är ny i kartong. och en DIY anvisning följer med oxå
600:- inkl frakt med bussgods
S: 03-08 Tiburon/coupe/tuscani Auto-Window Relay Kit
1kör svart SANTA FE 2.4l 02a
och silver COUPE 2.7 02a
