I started digging through the Tower ladders thinking it'd be a quick check, maybe a few obvious picks, then back to farming. Didn't happen. After watching top clears and comparing profiles, it became pretty clear that the Tower plays nothing like the pit diablo 4 crowd got used to. The Pit gives you room to settle in, build momentum, and grind out damage over a longer window. The Tower doesn't care about any of that. You get 10 minutes, floor pressure starts fast, and if your build needs time to wake up, you're already behind. That one difference changes the whole meta, and honestly, it explains why some popular builds just fall flat here even when they look great elsewhere.
Why Paladin keeps ruling the board
At the top end, Paladin is still miles ahead. Not a little ahead. Properly ahead. Judgment Paladin has become the solo benchmark because the build lines up perfectly with what the Tower asks for: burst, fast clears, and enough boss damage to delete the Guardian before the timer gets ugly. The playstyle feels direct too. You throw out damage, things stick, then everything pops. It's simple to describe, but the real story is gear. This build scales like mad once the items are right. A Paladin with decent gear can push, sure, but a Paladin sitting on 12/12 masterworks and near-perfect tempers is in a different universe. That's why the leaderboard gap looks so harsh. It's not only class balance. It's how brutally the Tower rewards perfect numbers.
Group play is a different game
Once you move from solo to group pushing, the logic shifts straight away. People who haven't played serious Tower groups often assume you just cram in more damage dealers. Usually that's a mistake. Support setups matter more, especially when a zDPS Paladin or Barbarian can multiply the whole team's output and smooth over dangerous moments between floors. That's where Oradin really starts to shine. With Dawnfire gloves in the mix, the aura value ramps into something a party can build around, not just a nice extra. It's one of those cases where the support slot doesn't feel optional. It feels like the reason the run works in the first place.
If you don't want Paladin
There are still solid options if Paladin isn't your thing. Pulverize Druid has earned its place because it survives the messy parts of Tower runs better than most. Those transition moments, when positioning gets weird and enemies pile in from bad angles, don't hit the build as hard thanks to shapeshifting and the natural toughness that comes with it. Spiritborn is worth a serious look too. Patch 2.5.2 fixed enough issues that Payback Thorns went from niche to genuinely competitive. And this is probably the biggest selling point: it's more forgiving on gear. You can get respectable Tower results without needing every item to look like it came from a fantasy wishlist.
What the Tower really tests
The more Rank 1 profiles you look at, the more obvious it gets that the Tower is mostly a prep check. Sure, execution matters a bit. You still need clean movement and good routing. But nobody's winning because they discovered some wild mechanical secret. They're winning because their gear is basically solved. Full masterworks, ideal tempers, the right uniques, no wasted stats. That grind is rough, especially if you don't have endless time for Obducite and Neathiron farming. For players who'd rather skip part of that wall and get the items or currency they need faster, U4GM is one of the services people look at, especially when the Tower timer only cares about whether your build has the raw numbers to finish the job.
