In every era of Path of Exile 2, there is always one build that feels less like a legitimate character setup and more like a glitch in reality itself. A build so absurdly powerful that players stop asking whether it is “good” and instead begin asking how long it will survive before the developers swing the nerf hammer.
Right now, that build revolves around one of the strangest and most explosive interactions currently discovered in the game: the interaction between Incinerate and Oil Grenade Ignite compounding.
And honestly? It feels completely illegal.
With Patch 0.5 approaching and Grinding Gear Games preparing major balance changes, many players believe this build is living on borrowed time. What we are witnessing may become one of those legendary moments in POE history — a short-lived period where a bugged interaction accidentally created one of the strongest damage engines ever seen in the game.
This is not just strong.
This is “delete the screen while standing still” strong.
Understanding Ignite in POE 2
To understand why this build is so ridiculous, you first need to understand how Ignite normally works in POE 2 Chaos Orbs.
Under standard conditions, Ignite follows a simple rule:
When you apply a new Ignite to an enemy, the game compares it to the previous Ignite already active. If the new Ignite is stronger, it replaces the old one. If it is weaker, it is ignored. The duration may refresh or extend, but the damage itself does not infinitely stack.
This is important because Ignite is normally balanced around controlled scaling. You are supposed to create a powerful burn, sustain it, and amplify it through modifiers like:
Fire Damage
Damage Over Time
Ignite Magnitude
Elemental Penetration
Exposure
Critical scaling
The system is intentionally designed to prevent infinite exponential growth.
Except one skill appears to completely ignore that philosophy.
Why Incinerate Is Different
The centerpiece of this build is Incinerate, the flamethrower-style skill that unleashes a continuous stream of fire damage.
On its own, Incinerate already feels strong due to its rapid-hit nature and consistent Ignite application. But hidden inside the skill is a mechanic that changes everything:
Ignites from Incinerate can compound.
That single mechanic is what transforms this build from powerful into absurd.
Normally, repeated Ignites overwrite each other. Incinerate does something different. When the target is already Ignited by Incinerate and receives another Ignite from the same skill, the new Ignite inherits damage from the previous Ignite.
In practical terms, the burn snowballs.
Instead of replacing old damage, it absorbs it and grows stronger.
Then it happens again.
And again.
And again.
At first glance, this might sound balanced. After all, plenty of games have ramping damage mechanics. But the real insanity begins once Oil Grenade enters the equation.
The Oil Grenade Interaction That Breaks Everything
Path of Exile 2 features numerous environmental interactions, and Oil Grenade is one of the most interesting examples.
Normally, Oil Grenade creates an oil-covered area that can ignite when exposed to fire. Once ignited, the burning oil transfers damage into a damaging fire ground effect.
That sounds straightforward.
But currently, something appears to be bugged.
For reasons players are still trying to fully understand, fire ground created through Incinerate ignition seems to inherit the compounding property from Incinerate itself.
And this is where the build completely breaks.
The process looks something like this:
Use Incinerate to apply Ignite.
Throw Oil Grenade onto the burning area.
The oil ignites and creates fire ground.
That fire ground somehow inherits compounded Ignite values.
Throw another Oil Grenade.
The new ignition absorbs the previous fire ground damage.
Repeat infinitely.
Every additional Oil Grenade increases the damage further.
There does not appear to be a meaningful cap.
No reset.
No diminishing returns.
The damage simply escalates into absurd territory.
The result is a growing inferno that melts bosses in seconds and vaporizes entire screens of enemies without requiring traditional burst setups.
This is not normal scaling.
This is exponential detonation.
Why Players Believe It’s Bugged
The reason the community overwhelmingly believes this interaction is unintended comes down to how POE systems are normally structured.
Grinding Gear Games is famous for allowing extremely complex interactions. Some of the strongest builds in franchise history emerged from clever combinations that developers intentionally left untouched because they rewarded creativity.
But this situation feels different.
The key issue is that environmental fire ground should not logically inherit a compounding Ignite mechanic intended for direct skill-based Ignite application.
The game appears to be treating each newly ignited oil surface as a continuation of the previous Incinerate burn state. Because of that, every new fire ground instance effectively “feeds” on the previous one.
This creates a feedback loop.
And feedback loops in ARPGs almost never survive balance patches.
Players have already started comparing this interaction to infamous historical builds from the original Path of Exile — builds that dominated briefly before being completely erased from existence.
The difference is that this one feels even more dangerous because it scales through environmental chaining rather than traditional stat investment.
The Gameplay Experience Feels Completely Unreal
Watching this build in action almost feels like watching the game engine struggle to keep up.
At lower levels of scaling, enemies simply disappear the moment they touch the burning ground. Elite monsters barely survive long enough to finish attack animations. Entire packs dissolve before players even properly register what happened.
But once the compounding ramps high enough, bosses become the real spectacle.
Normally, POE bosses are designed around movement, positioning, mechanics, and sustained damage windows. This build ignores most of that.
You are effectively building a continuously escalating nuclear reactor beneath the boss arena.
Every additional Oil Grenade amplifies the damage zone further until health bars begin evaporating at speeds that look blatantly unintended.
And because the damage comes from persistent ground effects, the player often does not even need perfect aim or complex rotations.
You simply keep feeding the fire.
The fire handles the rest.
Why This Build Represents Peak POE Chaos
Part of what makes Path of Exile 2 so fascinating is that the game constantly exists on the edge of breaking itself.
That has always been part of the franchise’s identity.
Unlike many modern ARPGs that tightly restrict interactions, POE systems are designed with extraordinary flexibility. Players combine mechanics from gems, passives, ailments, environmental effects, ascendancies, and item modifiers in ways even the developers sometimes fail to predict.
The result is a game where discovery matters as much as execution.
Sometimes that leads to balanced innovation.
Sometimes it creates monsters like this build.
And honestly, moments like these are part of why the community loves the game so much. There is something uniquely exciting about logging into an ARPG and discovering that the rules of reality have temporarily stopped functioning correctly.
For a brief window, players become alchemists experimenting with unstable magic systems.
This Incinerate interaction feels exactly like that.
A catastrophic accident.
A beautiful one.
The Shadow of Patch 0.5
The timing of this build is what makes it especially interesting.
Patch 0.5 is approaching rapidly, and many players expect sweeping changes across multiple systems. Whenever a major balance update arrives in Path of Exile 2, unintended interactions are usually among the first targets.
And this build has “hotfix me immediately” energy written all over it.
There are several possible ways Grinding Gear Games could address the issue:
Remove compounding from environmental Ignite sources
Prevent Oil Grenade from inheriting Incinerate properties
Cap compounded Ignite scaling
Reset Ignite state between fire ground generations
Rework how burning ground snapshots damage
Any one of these changes could instantly destroy the build.
In fact, it is hard to imagine this interaction surviving untouched for long. The scaling potential is simply too extreme compared to conventional builds.
That is why many players are treating the current version of the build almost like a historical event.
Not just a meta build.
A temporary phenomenon.
Something players will talk about months later with phrases like:
“Remember the Incinerate Oil Grenade era?”
The Fascinating Thing About Broken Builds
Broken builds in ARPGs are weirdly important.
Even when they are unhealthy for balance, they often become defining memories for the community. They create stories. They create eras. They give players moments that feel impossible.
Some of the most beloved moments in ARPG history came from wildly overtuned interactions that lasted only a few weeks before disappearing forever.
Because for a short time, players get to experience what it feels like to transcend the game’s intended limits.
That is exactly what this build delivers.
It transforms Ignite from a normal damage-over-time mechanic into an endlessly escalating inferno engine capable of consuming entire encounters.
And the craziest part is that it may already be living its final days.
A Build That Probably Won’t Survive
If there is one thing the POE community understands, it is this:
When a build starts looking too insane, its lifespan becomes limited.
This Incinerate and Oil Grenade interaction feels less like a carefully tuned strategy and more like a coding accident that accidentally escaped into the live servers.
But until Patch 0.5 arrives, it remains one of the most overpowered things players can currently experience in Path of Exile 2.
And honestly, there is something special about that.
Because years from now, long after the interaction is patched out and forgotten by newer players, veterans will still remember the brief moment when fire itself became unstoppable buy POE 2 Chaos Orbs.
The moment when every Oil Grenade made the flames stronger.
The moment when Incinerate broke the rules of the game.
And for one chaotic stretch of time, players got to wield one of the most absurd builds POE 2 had ever seen.
