Inte ens när jag körde engelskt hade jag så där mycket verktyg med mig... (fast någon gång hade det nog behövts)
Jänkare kan man titta på
HÄR
Och ni som (oxå) är bekanta med Lucas...Han hade inte så fel ändå!
Smoke makes all things that are electrical work. Remember the last time smoke escaped from a transformer? Didn't it quit working? I sat and smiled like an idiot as more of the truth dawned. I remembered when I'd witnessed the awful destruction of a four-kilovolt breaker and bus at Sunnyvale. The breaker and bus had leaked out so much smoke that they actually melted and quit working. See, it's the conductor that carries the smoke from one device to another. It starts at a power plant where the stuff is burned to produce smoke. The smoke we see coming from the stacks is excess that the system doesn't need. The smoke is then sent down the conductors to transformers. Transformers are big and require lots of smoke to work properly. That's why the conductors are so big. If those conductors spring a leak, it lets the smoke out of everything, and then nothing works! Forget about electron theory!"
[2026-07-29] På grund av
spam,
orelaterade poster och obefintlig moderering/
blockering av dessa så tackar jag för mig. Ev länkar i poster kan fungera... eller inte...
