If you like upsetting people in drag lobbies, the Autozam AZ-1 is exactly the sort of silly little car that makes the game fun. It's cheap, odd-looking, and easy to ignore, which is why it works so well as a sleeper. You don't need to burn through loads of Forza Horizon 6 Credits just to get started, either. The car costs 38,000 CR from the Autoshow, and it can also show up through Wheelspins if luck's on your side.
Quick route to getting the AZ-1
The stock AZ-1 doesn't look scary at all. It sits in D Class with a 342 PI, runs rear-wheel drive, and uses a tiny turbocharged 657cc inline-three making 63 horsepower. On paper, that sounds hopeless. In practice, it's just the blank canvas. The car weighs only 1,587 pounds, and that matters a lot once you start adding power. Less weight means less work for the engine, sharper launches, and a better chance of catching bigger cars sleeping.
Buy it from the Autoshow for 38,000 CR.
Check Wheelspins if you'd rather save your credits.
Keep the build focused on launch, grip, and low weight.
Don't judge the car by its stock horsepower, because that's the trap.[/list]
Parts that make the build wake up
The main idea is simple: give the AZ-1 power, then make sure it can actually put that power down. A 2.0L R3-T engine swap is a strong starting point, and the AWD conversion makes the car far easier to launch. Drag tires are also non-negotiable if you're chasing short-strip consistency. People often try to overbuild the car with random parts, but the better approach is to pick upgrades that help the first few seconds of the run.
Why this tiny car works on the strip
What makes the AZ-1 funny is that it doesn't need to look fast. Its mid-engine layout helps balance the car, and once AWD is added, it digs into the road harder than most players expect. Race weight reduction, a race driveline, wider rear tires, race anti-roll bars, rally springs, and a drift differential can all help shape the build. It won't feel like a normal kei car anymore. It'll feel twitchy, punchy, and a bit rude in the best possible way.
A budget sleeper worth building
The AZ-1 is best for players who enjoy winning in something that looks completely out of place. It's not about showing up with the most expensive hypercar. It's about tuning well, launching cleanly, and watching someone in a pricier machine wonder what just happened. If you're planning more builds and comparing upgrade costs, checking Forza Horizon 6 Credits for sale can help you budget around future projects, but the AZ-1 itself proves you don't need a fortune to have a properly quick drag car.
Återgå till "Allmänna frågor om Hyundais modellsortiment"
