Re: lampinsats
Hur har det gått?
Manualen tycker att man ska bort stötfångaren medan andra har lyckats ändå.
Små händer rekommenderas också. Tänk på att barnarbete dock är förbjudet i de flesta länder.
Fann detta, kanske är det till någon hjälp. Har du lyckats ändå så får du jättegärna skriva ett inlägg i DIY.
1st
to remove the sealing lids that cover the back of the bulbs access; these can be removed by rotating them anti-clockwise.
Use the back of a screwdriver on the flaps to turn the lid and when you feel that it doesn’t turn anymore just pull them back
2nd
THIS ISN'T NEEDED BUT IT HELPED ME BIG TIME!!!!
Also remove one of the two high beam lids. In fact you have to remove the bulb. This is made easy because this support has a plastic tool that clips perfectly on the back of it so that it can be turned anti-clockwise to remove the bulb.
Once you have the high beam bulb out remove the plastic tool from the bulb support with a small flat screw driver. The plastic tool has a small lip that needs lifting to release the support.
3rd
Once you have the tool, clip it onto the bulb support of the dipped beam. Now turn the support, it is tricky I know but have patience and it will turn.
4th
Now replace the bulb with the new one.
Now this is important: remove the plastic tool from the support and put it back on but not as far as it clips back on. You must not let this happen otherwise the plastic tool cannot be removed from the support; there is no space for you to do that! In case it does just get the bulb out again and try again.
After the bulb is in place, you will feel that it rests flat on a surface and can be turned clockwise to lock into place
Pull the plastic tool off and now do the other side. After this being done remember to place the high beam bulb back into place and leave the plastic tool on it.
Close all the lids by just doing the reverse steps (see initial part)
