For POE divine orbs players looking to make serious currency this league, a clever hideout crafting method has been quietly generating huge profits: recombinator crafting on rare bases. While not everyone has been deep into hideout warrioring this league, some players have already turned this into a major source of income, creating multiple high-value items in just a few hours.
The strategy revolves around using recombinators to upgrade rare bases to higher item levels, then splitting them for maximum market value. For example, cord belts are a prime candidate. By purchasing low-to-mid level belts and upgrading them to item level 86, players can then apply fractured fossils to generate split items, effectively doubling their output.
Key steps in the process include:
Purchasing appropriate bases – Target items like cord belts at item level 82–83. Buying the cheapest viable base ensures the most efficient use of currency.
Scouring and preparing – Scouring items before recombination reduces the cost of theurgic dust, a scarce resource, while using minimal alteration orbs to manipulate the minimum level helps control expenses.
Recombination – Using the recombinator carefully, players combine items in 50/50 or "unstable" modes. The higher the base level, the better the outcome, though some randomness always applies.
Splitting items – Fractured fossils allow for duplicating the item, creating split versions that retain high desirability on the market. This step is crucial for maximizing profit with POE currency.
Selling – Once prepared, these high-level belts can be listed for two divines each, often selling within minutes. Profit margins are significant, with crafting costs usually around 150 chaos per item.
While this exact method may no longer yield the same extreme profits due to market saturation once widely adopted, it illustrates the potential of targeting high-demand item levels. The same logic can apply to other items, such as archdemon crowns, where the difference between item levels 83–86 can drive market value significantly, even if the higher level isn't mechanically superior.
For players looking to dive into hideout crafting and market manipulation, the takeaways are clear: understand the value of item levels, optimize resource usage, and watch the market carefully. With the right preparation, recombination crafting can still be a lucrative path to currency in Path of Exile.
