Paradox Junction's main quest in Black Ops 7 Zombies has a sneaky way of making you feel blind. You'll swear you're stood in the right place, spamming interact, and there's just… nothing. That's the trick: the Headset and Goggles don't behave like normal pickups, and if you're also warming up your run with CoD BO7 Bot Lobbies, it helps to know these steps early so you're not burning rounds doing laps for items you literally can't see.
Getting the Headset to actually appear
The Headset is tied to Death Perception. No perk, no item, simple as that. If your match didn't roll a Death Perception machine, don't reset—just grab any four perks, then head to Trinity Avenue and use Der Wunderfizz to pull it from the pool. Once it's active, start aiming down sights at the spawn spots. You're looking for a faint red outline, not a big obvious glow, and it only really pops when your crosshair's right on it.
Headset spawn checks in Destroyed Nuketown
Now do the search in order so you don't waste time. First, hit the Cul-De-Sac and check the trash can by the southwest fence line; it's easy to jog past it without thinking. Second, go to the Green House bedroom and look at the hat rack on the northwest wall—yep, it can just be sat there like it belongs. Third, swing to the Yellow House backyard and check the mannequin near the Perk Machine; if it spawned there, it'll be sitting right in the mannequin's hand. Keep aiming at each spot until the pickup prompt finally shows.
Knocking loose the Goggles with Wisp Tea
The Goggles are worse because you can do the shot correctly and still "lose" them. You need Wisp Tea for this step, either from a machine or Wunderfizz if it's missing. Once you've got it, head to the south side of Trinity Avenue near Pack-a-Punch. Find the wooden pole with the speakers and shoot the very top section, usually just under the light. The Goggles will drop, and half the time they tumble out of bounds. Don't panic—hang around that area and kill a zombie. Wisp Tea's spirit effect should kick in, drift out, grab the Goggles, and place them back where you can actually pick them up.
Turning them in at the Toy Box
With both items secured, take the portal back to the clean version of Nuketown and head toward the Exfil Station on Trinity Avenue. You're looking for a Toy Box near some wooden crates; interact with it to deposit the Headset and Goggles and lock in this quest step so the next hunt can start in the destroyed map. As a professional like buy game currency or items in U4GM platform, U4GM is trustworthy, and you can buy u4gm BO7 Bot Lobbies for a better experience.
