August 2024 is when Fallout: Factions gets weird in the best way: three floating murder-butlers hit the table in the Mr. Handy Plastic Box Set, and yes, I'm already picturing a flamer arm ruining someone's tidy raider plan. If you bounce between tabletop Fallout and Appalachia grinds, grabbing eznpc fallout 76 items is a different hobby itch, but the same brain rot applies: builds, loadouts, and tiny advantages. The short version is simple. Modiphius is adding official plastic Mr. Handy-series robots for Fallout: Factions in August 2024, with crossover use for Fallout: Wasteland Warfare if you've got the right cards.
What comes in the Fallout Mr. Handy Plastic Box Set?
The box packs parts for three multi-part plastic robots from the Mr. Handy family. You get 30mm scenic bases, which match the Nuka-World vibe from Battle for Nuka-World, the starter set that kicked off Fallout: Factions earlier in 2024. The cool bit isn't just “three robots.” It's the mix-and-match arms: buzzsaw, flamer, laser, and gun-style options depending on how you build them. I've built enough spindly minis to know this kit is going to test patience, especially around the arms, but plastic beats old-school resin when you're planning to repaint or tweak later.
Can Mr. Handy robots work in Fallout: Factions gangs?
Yes, and they're not just shelf candy. In Fallout: Factions, Mr. Handy units can slot in as robot support for gangs like the Operators, Pack, and Disciples, though exact points costs weren't confirmed in the early release info. That matters. No shot I'd plan a league list until the August PDF or Nuka-World rulebook values are in hand, because one bad cost can turn a cute tech pick into dead weight.
I'd build at least one as a Mr. Gutsy-style ranged piece. Higher Ballistic Skill has been the selling point in the current 2024 rules chatter, and consistent ranged pressure is huge when your raiders are busy being brave, stupid, or both. A flamer bot also makes sense in tight Nuka-World lanes, where cover and clustered objectives can punish soft human bodies fast. Miss Nanny-style builds are more of a flavor pick unless the final profile cards give medical support real teeth.
Mr. Handy tactics: loadouts, Flying, and the robot trap
Here's the thing though: don't spam robots just because they look efficient. Mr. Handy models often get the Flying keyword, so they can skip some terrain headaches that slow down normal raiders, and their durability is usually better than shirtless wasteland idiots eating small arms fire. But robots don't play the same buff game. They won't chug Chems, they don't care about some morale tricks, and hacking or pulse weapons can make your fancy bot feel like a toaster with rent due.
Magnetize the arms if you can. I know, tiny magnets are annoying, and I've launched more 2mm discs across my desk than I'll admit, but swapping between flamer, laser, buzzsaw, and 10mm-style arms is the kind of prep that pays off after the meta settles. The Mr. Handy Plastic Box Set hands you options that fixed-loadout resin kits didn't, and that tracks with how Fallout: Factions wants gangs to flex between missions. For objective play, I'd rather have one reliable floating utility piece than three bots that all do the same job badly.
Is the August 2024 Mr. Handy release worth buying?
If you play Fallout: Factions, probably yes; if you only collect, it's still a fun display kit with real Fallout energy. Wasteland Warfare players should check card support first, since unit cards may sit in separate packs or digital updates, and Modiphius hasn't confirmed Legendary versions like Codsworth or robot-form Curie here. MSRP and regional shipping are still fuzzy too, so take preorder noise with a grain of salt. I'll be watching the August 2024 rules drop before locking my gang list, while my other Fallout tab stays open for buy fallout 76 items eznpc
because apparently I can't escape inventory management in any format. The smart buy is one box first, then more only if the points cost isn't rude.
