Wave 100 in Bee Dungeon isn't something most players stumble into by luck anymore. The update made the mode tougher, but also a lot more rewarding if you plan properly. You'll feel the difference almost straight away: weak hives get pushed back early, while prepared teams move through waves with far less panic. That's why many players now spend time checking upgrades, trading resources, and comparing GAG Items before they even queue for a serious run.
Team runs feel much safer
Going in solo sounds tempting, especially if your hive looks strong on paper. In practice, it's usually a rough ride. A four-player group with maxed combat upgrades is far more reliable, because the pressure gets spread out. One player can focus on tanky bees, another can stack damage, and the others can cover support or clean up loose enemies. You don't need a perfect squad, but you do need people who know what they're bringing. Random hives with no plan tend to fall apart once the waves start hitting harder.
Enchantments matter more than most players think
The Bee Enchantment system is the part of the update that really changed the meta. Spear is great when you want faster attacks and steady damage. Sword is the easy pick for aggressive builds, especially because the extra critical chance adds up fast. Shield works best on bees that need to stay alive and hold the line. Crown is more about speed and utility, so it has its place, but it's not always the first choice for dungeon pushing. Bee Shard is the dream option. It boosts everything, adds crit, and fits almost any serious endgame setup.
Necromancer and Chaos Bees still have clear jobs
Necromancer Bees aren't topping damage charts by themselves, but that doesn't make them weak. Their Skeleton Bees can soak hits, block pressure, and buy time for your damage dealers. Put Shield enchantments on them and they become far more annoying for enemies to break through. Chaos Bees sit on the other side of the plan. They're there to hit hard and clear waves quickly. A hive with a strong batch of Chaos Bees, especially with Sword enchantments, can tear through mid and late waves before the screen gets too messy.
Illusion Bees are the real prize
If you've played a few high-wave runs, you'll know why everyone talks about Illusion Bees. Their base damage is already strong, but the extra summoned bees make them feel unfair when the setup is right. Sword enchantments push their damage even higher, while Bee Shards turn them into all-round monsters. Overlord Bees also deserve a spot because their stat boosts help lower-tier and Mythical bees perform better across the hive. A balanced lineup with Necromancers in front, Chaos Bees dealing damage, Overlords supporting, and Illusion Bees carrying the heavy fights is one of the safest ways to chase Wave 100.
Getting more from every dungeon run
Rewards are the reason players keep grinding Bee Dungeon, but speed matters too. Faster clears mean more chances at rare drops, better farming sessions, and less wasted time after a failed run. Some players also look at GAG Tokens for sale when they want to speed up progression or prepare for stronger builds, though the smartest move is still learning how your hive works under pressure. Build around roles, upgrade before entering, and don't treat Wave 100 like a casual farm.
