Path of Exile 2 continues to surprise players with powerful build interactions, POE 2 Orbs, and clever mechanics that can dramatically increase character performance. As the latest league introduces a variety of Runic Ward-based skills and systems, players are already discovering ways to push damage output far beyond what was initially expected.
Among the most exciting discoveries is a surprisingly simple interaction that can provide an enormous damage boost for attack-based builds. By combining the new Reputation skill with a powerful Ancient Augment known as Ulaman's Gaze, players can effectively gain a massive damage multiplier while simultaneously improving their critical strike consistency.
The setup requires very little investment, works across a wide range of attack builds, and can be particularly devastating against bosses. While it may eventually attract balancing attention due to its strength, for now it remains one of the most powerful offensive tricks available in the current league.
Understanding Runic Ward
Before diving into the interaction itself, it's important to understand how Runic Ward works.
Runic Ward is one of the new defensive mechanics introduced in the current league. Players can acquire it through various methods, including socketing specific runes into gear or using Rune Forager modifications that trade some defensive stats for additional Runic Ward.
At its core, Runic Ward acts as an extra layer of effective health. It absorbs damage separately from traditional defenses and can provide an additional buffer against incoming attacks.
Under normal circumstances, heavily investing into Runic Ward is not always the most efficient defensive strategy. Sacrificing armor, evasion, or energy shield for more ward can sometimes leave characters feeling more vulnerable overall.
Fortunately, this damage setup requires almost no investment.
In fact, many players only need a single source of Runic Ward to make the entire interaction functional. Even a modest amount of ward is enough because the strategy focuses on activating a specific skill rather than scaling the ward value itself.
This low barrier to entry is one of the reasons the interaction has become so popular among experienced players.
The Key Skill: Reputation
The foundation of the entire strategy revolves around the new skill called Reputation.
When activated, Reputation consumes all available Runic Ward and grants a temporary buff. While this buff is active, the character automatically blocks all blockable incoming hits and applies the Parried debuff to enemies whose attacks are blocked.
The buff lasts for approximately four seconds and creates a powerful offensive opportunity.
On its own, Parried does not appear particularly impressive. The debuff exists primarily to interact with specific skills and mechanics throughout the game. However, Reputation adds an additional effect that transforms Parried into an incredible damage amplifier.
Enemies affected by Reputation's version of Parried take 50% more attack damage.
That single line is what makes the mechanic so powerful.
A 50% more damage multiplier is enormous in Path of Exile 2's damage system. Unlike additive increases that stack with countless other bonuses, "more" multipliers are multiplicative and therefore far more valuable.
For attack builds, this effectively creates a temporary boss-killing window where damage skyrockets.
There is one important limitation: the interaction only benefits attack-based characters. Spellcasters cannot take advantage of the attack damage multiplier because the bonus specifically increases attack damage dealt to the target.
For melee and ranged attack builds, however, the effect is extraordinary.
The Trade-Off
Naturally, such a powerful buff comes with a downside.
While Reputation is active, players suffer from a 50% reduction to stun threshold. This means characters become significantly easier to stun during the buff duration.
At first glance, this sounds dangerous.
Fortunately, Reputation simultaneously blocks incoming attacks, meaning many of the hits that would normally threaten the player are prevented entirely.
In practice, most players activate Reputation immediately before engaging a dangerous boss mechanic or during a damage phase. The goal is simple:
Activate Reputation.
Allow the boss to hit you.
Trigger the Parried debuff.
Unload your strongest attacks.
Once the enemy becomes Parried, the damage amplification begins immediately.
For many builds, this four-second window is enough to remove a huge portion of a boss's health bar.
Enter Ulaman's Gaze
While the 50% more attack damage multiplier is already impressive, the interaction becomes truly absurd when paired with Ulaman's Gaze.
This Ancient Augment can be socketed into an Abyss Eye setup and currently commands a substantial market price due to its power.
The augment contains a deceptively simple modifier:
Your Critical Hit Chance is Lucky against Parried Enemies.
To understand why this is so strong, players need to understand the Lucky mechanic.
What Does Lucky Critical Strike Chance Mean?
In Path of Exile, Lucky means the game effectively rolls twice and uses the better result.
For critical strike chance, this translates into dramatically improved consistency.
Imagine a build with a 50% critical strike chance.
Normally, each attack has a 50% chance to crit and a 50% chance not to crit.
With Lucky critical strikes, every failed critical strike roll gets a second chance.
The practical result is not exactly double critical strike chance, but it dramatically increases effective crit frequency.
For many builds operating around 40-60% critical strike chance, Lucky critical strikes can push actual crit rates into extremely high territory.
This alone would be powerful.
When combined with Reputation, however, the result becomes devastating.
Players are now applying a debuff that causes enemies to take 50% more attack damage while simultaneously gaining dramatically improved critical strike reliability against those same targets.
The two mechanics stack together to create a massive burst damage window capable of deleting bosses in seconds.
Why the Combination Is So Powerful
Most damage increases in Path of Exile 2 require substantial investment.
Players often need expensive weapons, rare jewels, optimized passive trees, and carefully crafted gear to achieve meaningful gains.
This setup is different.
The Reputation component requires only a small amount of Runic Ward.
The Ulaman's Gaze component requires a single augment.
Together, they create multiple layers of offensive scaling:
Increased attack damage through Parried.
Significantly improved critical strike consistency.
Better critical strike uptime.
Enhanced burst potential during boss fights.
Minimal passive tree investment.
The result is a damage increase that feels far larger than the investment required.
Many players report seeing boss health bars disappear dramatically faster once both components are combined.
Bossing Applications
Where this setup truly shines is boss combat.
Mapping enemies often die too quickly for the full interaction to matter. By the time Reputation applies Parried, many regular monsters are already dead.
Bosses are a completely different story.
Because bosses survive long enough to attack the player, activating Reputation becomes extremely reliable.
The sequence usually looks like this:
Activate Reputation before entering a damage phase.
Allow the boss to land a blockable attack.
Apply Parried automatically.
Trigger Lucky critical strikes through Ulaman's Gaze.
Unload your primary damage skill.
Watch the boss health bar melt.
This strategy is especially effective against encounters with predictable attack patterns, allowing players to intentionally trigger the debuff exactly when they need maximum damage output.
Optimizing Reputation
Players looking to maximize the interaction should prioritize increasing Reputation's gem level.
Higher gem levels extend the duration of the Parried debuff.
While the difference between lower and higher levels may seem small, every additional fraction of a second provides more opportunity to capitalize on the damage window.
A level 20 Reputation grants nearly four seconds of uptime, giving players plenty of time to unleash powerful attacks.
Support gems can further improve consistency.
Popular support options include:
Prolonged Duration
Extends the uptime of Reputation and its associated effects.
Cooldown Recovery
Allows more frequent activations during extended encounters.
Efficiency
Reduces resource strain and improves overall usability.
Second Wind
One of the most valuable support choices.
Second Wind grants an additional charge, allowing players to activate Reputation multiple times before waiting for a full recharge.
This creates much higher uptime and enables players to maintain offensive pressure throughout long boss fights.
Is It Too Strong?
Whenever players discover interactions that provide enormous power with relatively low investment, balance concerns naturally arise.
Many community members already believe this combination may eventually receive adjustments.
The reasons are easy to understand.
A 50% more damage multiplier is already exceptionally strong.
Adding Lucky critical strikes on top creates another substantial layer of scaling.
The setup works on a huge variety of attack builds rather than being restricted to a niche archetype.
Most importantly, the investment required is remarkably small compared to the rewards.
Whether Grinding Gear Games decides to alter the interaction remains to be seen, but many players are taking advantage of it while it remains available.
Final Thoughts
Path of Exile 2's newest Runic Ward mechanics have opened the door to some fascinating build possibilities, but few are as immediately impactful as the Reputation and Ulaman's Gaze combination.
By investing in a small amount of Runic Ward, players gain access to Reputation's powerful Parried debuff, causing enemies to take 50% more attack damage. Pairing this with Ulaman's Gaze transforms those same targets into ideal victims for Lucky critical strikes POE 2 Orbs for sale, creating a devastating burst damage window that can shred even powerful bosses.
The setup is easy to integrate into existing attack builds, requires relatively little investment, and delivers results that feel far beyond its cost. For players seeking a straightforward way to dramatically increase their damage output in the current league, this interaction may be one of the strongest hidden technologies available.
Whether you're pushing endgame bosses, optimizing a crit-based character, or simply looking for an efficient way to boost your damage, this Runic Ward combo deserves serious consideration before future balance changes arrive.
