Tired of standing still and dealing damage in Path of Exile 2? Want a playstyle that's all about constant movement, explosion-filled clears, and pure adrenaline? Today we're breaking down this off-meta but brutally effective Templar build: roll once, summon a stag, blow up the whole screen with POE2 Currency, lightning, outrun mounts, and melt endgame bosses. From league start to pinnacle content, it's smooth sailing. Read on and you'll be ready to go.
Core Gimmick: Roll a Stag? Who Came Up With This?
This build revolves around the Templar ascendancy skill "Vital Rush." The rule is laughably simple: every 10 meters you move generates one Lingering Light. Store up those charges, and your next attack launches an explosive stag. The stag detonates on contact, applying lightning shock to all enemies in the area. You can store up to 3 charges, meaning three rolls = three exploding stags in a row. Movement literally becomes damage.
Rotation: run/roll → generate light → throw a grenade → trigger stag → roll again → repeat. Never stop moving.
Who is this for?
Perfect for new Templar players who find complex mechanics intimidating. You'll grasp the core loop instantly without trial and error.
Roll Like a Pro: Stack Roll Distance to 10m - One Roll, One Stag
This build doesn't rely on running. The key is stacking roll distance. Target: slightly above 10m per roll. Hit that threshold, and each roll gives you one Lingering Light. Here's the combat flow: roll into a pack → generate light → throw grenade → stag explosion → roll to dodge → repeat. You're almost never stationary, so mobs can't touch you.
Who is this for?
Players struggling to hit the light generation breakpoint. We give you the exact stat target so you don't waste gear.
Why Grenades as the Trigger Skill?
Any attack can trigger the stag, but grenades are the best by far - almost zero wind‑up animation, no interruption to your rolling rhythm. Recommended loadout:
Explosive Grenade - general clear
Cluster Grenade - high density
Flash Grenade - area control
Rotate them to avoid cooldown gaps: roll → throw → explode → swap grenade → repeat. The pace is relentless.
Who is this for?
Players unsure which trigger skill to pick. This combo keeps your damage flowing and rhythm intact.
Ascendancy Order: Pick These Nodes First
Don't waste points. Follow this order for maximum gain at every stage:
Morgan's Guidance (league‑start essential): more reliable light generation, extra stag damage, and boosted shock - scales as you fight.
Primal Gift (mid‑game clear king): rolling gives extra grenade charges (not extra stags), hugely increasing clear coverage - twice the clearing speed.
Wild Guardian (newbie survival): summons a bear to taunt enemies - massive safety net against bosses.
Sacred Union (endgame transformation): stags gain homing - no aiming needed, they chase mobs down. Plus movement speed buff. Insane for clear and mobile bosses.
Who is this for?
Players lost on ascendancy order. Follow this and you'll never cripple your progression.
Passive Tree: Don't Stack Projectile Damage!
Common trap: stags are NOT traditional projectiles. Projectile damage nodes do almost nothing. Priority order:
Generic damage
Lightning damage
Shock effect
Grenade damage
Most of the high‑value damage nodes are on the warrior side of the tree - path there directly.
Who is this for?
New builders who need direction and want to avoid wasted points.
Boss Fight Optimization: Swap Weapons for Max Burst
For high‑health endgame bosses, don't use one loadout. Prep a secondary weapon set for extra damage - can shave off 30 seconds.
Secondary weapon: Oil Grenade, plus exposure passives and Impact Intensity. Oil Grenade applies exposure, lowering elemental resistances. Pair with Phantom Archer. When you swap back to your main set, the debuffs persist.
Boss sequence: swap → throw Oil Grenade → exposure applied → swap back → keep throwing grenades and summoning stags. Persistent damage amp throughout the fight.
Who is this for?
Players struggling with endgame boss DPS. Minimal investment, massive single‑target boost.
Defensive Mindset: The Best Defense Is Never Standing Still
This build is hyper‑mobile. Forget stacking life or ES. Defense priorities:
Evasion > deflection > constant movement
You're rolling constantly, so most attacks never hit you.
Extra survival tips:
Grab a few life/defense affixes on gear
Keep an emergency guard skill
Let your bear partner taunt threats
Keep moving - better than any defensive layer
Who is this for?
New players who keep dying with this build. Break the old "stack defenses" mindset and use mechanics to survive.
Quick Tips
Light generation inconsistent? Check your roll distance - just over 10m is enough. Overstacking is wasted; reinvest into damage.
Low on stats during leveling? Use the talisman slot with attribute catalysts - no need to hunt expensive gear.
Speed farming open maps? Swap a few survival nodes for movement speed - you'll outrun vehicles.
League start on a budget? Don't chase BIS gear. Prioritize roll distance first, then damage. A 5‑divine budget takes you far.
Summary by Playstyle
New / league‑start players - simple mechanics, low budget, smooth progression, no need to trawl trade for expensive cheap POE 2 Exalted Orbs.
Fast‑paced action lovers - never stand still, clear and move simultaneously, turns a grinder into an action game.
Off‑meta enthusiasts - unique mechanics, endgame viable, fresh feel that crushes all content without getting boring.
